Idler gear stock?
Going to make an order:
Gorilla Singlespeed Gorilla Motormount Gorilla XL Straps ...and a few cells. Would like an steel Idler gear to go with the order, if there is any in stock (or laying about ;)). Thanks. |
Oh and do you have any stiffer springs? These Integy ones are a joke. Thanks.
Right I need some help now. Advice on the UE 1/8th 6spyder diffs' - are these bulletproof? I might buy some 2nd hand and get the FLM Hydrids from here, just want to know if it's a good idea? 2nd hand diffs any wear etc'? Thanks.
Not sure what to do. I run Maxximizer now. Stuff in post 1, or this stuff? What would you get. |
not sure. but dont you already have bulkless'?
No, I have the FLM ones.
I've decided to go with the UE Extension, UE EXT center CVDs and Gen4 UE Servo saver. Should do my truck best, remove those nasty twisted center sliders and extend it for less wheelies and better performance. |
UE extender isn't available.. :(
waiting for mine too.. The 6spiders are good, though i am not carried away with their internal gears, though you could easily change them to the new HPI savage gears, which is much, much tougher. |
Yup, want the UE extension and EXT centres, both out of stock. Robin said the Monoblock is in production now.
whats the monoblock?
It's a chassis extension made by UE but it doesn't replace any parts like the Gorilla one does. It's basiclly a block spacer between the chassis and bulkheads.
| All times are GMT -4. The time now is 11:33 AM. |
