Help please with Hyperion 606i
Hi All,
o Just soldered the connectors onto my Neu Energy 5s 6500mah Lipo and connected to my Hyperion 606i thinking "great I can charge this battery in a little over an hour" The battery however even though set to charge @ 6amps, is only charging at 2.5A. Reading the manual the charger can onyl do 50W output max. Do I figure out the max charge amps for a 5S do I equate as follows: 50/18.5 = 2.7amps What charger will charge this a battery in an hour?? thanks again everyone :) |
The 610i NET or DUO, 720i, etc. should all do it in around 100 minutes. You'll need at least a 150 watt charger to charge that lipo at a full 6 amps. Keep in mind that it only charges at 6 amps for most of the charge then kicks over to constant voltage charging (as opposed to constant amperage) to "peak" the pack. I don't know if the newer Hyperions are programmable to only do the CC charge for faster charging but if you are in a rush to run your car you can pull it off the charger once the amperage really starts dropping.
| All times are GMT -4. The time now is 04:54 PM. |
