-   -   A Slash and a MMM combo (https://www.rc-monster.com/forum/showthread.php?t=22267)
jacobsjo87 07.13.2009 11:30 PM
I have a crazy brother that wants to make th most over-powered slash possible. He wants to run a MMM 2650kv system on 4s. Has it been done? From preliminary measurements I dont think the motor (41.78mm diameter) will fit in the gear box. So he would need a FLM tranny case, but then there is still the question of if the size of the motor will allow it to have good gear mesh with different gearing options. Has anyone tried it, or have any input?
Andrew32 07.13.2009 11:31 PM
you will have no tires......and tranny failure up your butt! haha
100% undrivable pwoer
itll be fun if you can strengthen all those parts...
scarletboa 07.13.2009 11:40 PM
you would be better off getting the 2200kv motor if you want the most power possible. the can on the 2200kv motor is longer and you would be able to gear it to the moon.
jacobsjo87 07.14.2009 12:05 AM
Thats exactly what I told him. A much better option would be a 50mm medusa and it still have just insane power.
fastbaja5b 07.14.2009 12:10 AM
I found the Slash even with a VXL on 3s is uncontrollable!
FLM Tranny case is a must, never had the motor over 110f running 18/86 on 2s OR 3s!
jacobsjo87 07.14.2009 12:15 AM
Thanks for the heads up on the tranny case. Does the stock one flex to much?
fastbaja5b 07.14.2009 12:24 AM
It does, also the Alloy one acts as a huge heatsink.
It is a bit of a PITA to install as it has no instructions (especially mounting the shock tower)
Metallover 07.14.2009 12:40 AM
50mm medusa would be the best in the longrun. Cool temps, gobs of power, yet not wayy too much power. Perfect choice for the slash.
Arct1k 07.14.2009 06:36 AM
Several of us have done this kind of stuff - medusa 50 or 60 is enough to shred diff's - the 2200 does it very well though
http://i168.photobucket.com/albums/u...k/Pede/034.jpg
http://i168.photobucket.com/albums/u...k/Pede/035.jpg
http://i168.photobucket.com/albums/u...k/Pede/036.jpg
skellyo 07.14.2009 09:30 AM
4S in a Slash is fun :mdr:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/9UqBpCK8Nf4&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/9UqBpCK8Nf4&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Bondonutz 07.14.2009 09:44 AM
Cool video.The bands names escapes me,who did that tune ????
skellyo 07.14.2009 09:49 AM
Korn - Here to Stay
Excellent CD...worth checking out
http://www.amazon.com/Korn-Greatest-...7579290&sr=8-1
Bondonutz 07.14.2009 09:54 AM
Doh ! Should have known that. I guess it's ben a while since I heard it. Even have the disc, What a dope. Thanks.
