-   -   jammin x1 crt gearing (https://www.rc-monster.com/forum/showthread.php?t=22305)
chase 07.15.2009 07:55 PM
anyone running these know the best combo for the 62t spur?
About 10t or 12t. Running the hobbywing 2350kv motor, on 4s 25c pack
riverat1540 07.15.2009 08:24 PM
id say thats about right maybe a 13 or 14 just watch ur temps,
chase 07.15.2009 11:30 PM
well it will be on a track so top speed isnt a must could it be geared lower?
riverat1540 07.15.2009 11:55 PM
u dont want to go too low as u will hit the center brace with the motor id say 13 maybe 12 is as low as u can go, sorry i didnt mention that first but it just popped in my head
chase 07.16.2009 07:53 AM
thanks
killerlst 09.30.2009 12:01 AM
i just got a jammin x1 crt with jr 8711 steering servo // mamba max 2200 motor and speed controller 5 cell 4000 mah 35c lipo battery.. zeilke racing body andand spare 3 size pinion gears truck was clocked at 70 mph on a wheelie insane speed also with spectrum receiver 2.4 dsm 2.0 controller
riverat1540 09.30.2009 09:53 AM
u must have some great tires,:gasp:
DonovanP 09.30.2009 12:32 PM
I had a 13t on my hobby wing system in my CRT and motor was 150deg/f and lipo's 115deg/f and esc 90deg.So went up to 15t and motor was 145deg esc and lipo's round 90deg/f.So going to try a 14t this weekend and see.Should be sweet spot I think..BTW i'm running the 2300kv HW system on 4s!
But getting my Tekin RX8 tomorrow with 2050kv motor.Think 15t will be good there!
riverat1540 09.30.2009 12:38 PM
on 4s i would gear around 35mph for best efficiency and cool temps, the bottom end power will not draw as many amps
Jesse M 09.30.2009 06:31 PM
Why would you want to use such a small pinion gear with a such a huge spur gear. I have a 17t spur with 62t Mutilator spur gear with 2300kv motor and 4/5s and its is dam slow.
riverat1540 09.30.2009 06:46 PM
you are geared for 47mph on 4s and 60 on 5s not including tire ballooning, i think your system is under too much load to get up to speed if u think it is too slow with a 17 tooth pinion and a 2300kv motor, i used a 14t pnion on the 62spur with factory diffs on 5s and neu 1515 1y geared for about 46 and it was plenty fast and was not under alot of stress , cool running setup. also the reason to use a smaller pinion with such a large spur is that the crt x1 has buggy diff's in it and does not use the truggy diff ratio which is why it uses the large spur.
