-   Slipperential discussion (https://www.rc-monster.com/forum/forumdisplay.php?f=45)
-   -   How do you hold your slipperential while tuning it. (https://www.rc-monster.com/forum/showthread.php?t=22341)
kalbien 07.17.2009 06:23 AM
Hi
I've been experimenting with slipperential and everytime I want to loosen/tighten it I am missing one arm.. or two actually. Do you have any trick how to hold everything to be able to tune it, while using just one hands? usually I just ask somebody to hold driveshafts for me so not a big problem, but if you have any trick how to make it easier, most appreciated.
Dafni 07.17.2009 06:33 AM
I don't hold the shafts, I just press the whole truck down so the wheels wont spin. Then you can turn the nut a bit, move the truck a bit, and give the nut another bit of a turn.
Or when it's already pretty tight, you can grab the spur itself. Works up to a point, when it starts to slip when you turn the nut.
Hope that helps
Daf
kalbien 07.17.2009 06:39 AM
Hope that helps
Daf
Or I can move whole truck a bit while holding adjustments tool ;) I am running it quite tight so need to hold spur down. But I will try to move & push down whole car, that might work. Thanks
