Brushless Motor & Solder Gun
Hey Guys,
While desoldering my connectors off of a dead motor, check out what happens.. Would that be single phasing?..:lol: http://www.youtube.com/watch?v=Kx73b...eature=related |
LOL
Yup, the difference in voltage between the two points on the resistive soldering tip makes it possible to cause a short circuit into the motor, only a small current im sure. Better watch out though, you could overload the coil inside the soldering iron... |
really will it overload the solder gun, even though that the ends are closed circuits...
Well, probably not, you would most likely have to do that for a awhile...
| All times are GMT -4. The time now is 01:56 PM. |
