Bulkheads
Which are the better bulkheads from the site, fastlane or integy?
Thanks. |
Ue :005:
You mean bulkless? That means i would have to sell my 1/8 diffs, shock towers and plastics bulks. That alot of work.
FLM, integy is light but it is molded and VERY weak, flm is very durable, and if you manage to break it, the replacements are cheap.
actually the newer integy stuff is pretty strong as well as light. if im not mistaken mike runs the integys on one of his trucks, although im not 110% positive.
will integy be strong enough tho? I mean where does it bend.
integy bulkheads should be strong enough but i would reccomend the flm bulkless
Why would you sell your 1/8 diffs. ? Use the gears in the FLM 1/8 Hybrids |
If i were to buy a VBS, wouldnt i have to sell my 1/8 ue diffs?...
Are these flm hybrid compatible with the ue 1/8 diffs... Maybe they might be a better choice then. |
Double post.
Yeap
Whats the difference between flm hybrids and flm combo? So basically if i bought the VBS i would need to sell my shock towers, bulkheads, and 1/8 diff cases??
And the FLM's will to and at a lower $$$$
| All times are GMT -4. The time now is 10:40 AM. |
