From The Ground Up, 1/5 build.....
I was looking on the large scale section of RCU, and came across this completely custom 1 off 1/5 electric build. Some of the best CNC machining I have ever seen, and one of the biggest Lehner motors I have ever seen. Check it out - http://www.rcuniverse.com/forum/m_8867256/tm.htm
Anyone wanna take a guess on the weight of that thing is? This is one of those build that when you think you've made something awesome you find out that you've just been one-upped.
That thing is pretty sick looking, Must be nice owning your own CNC machines ?
somebody give that guy a bec!
how 'bout the size of that schulze, and its decorative display case dig all them fans BrianG? awesome work!!!! |
impressive work
^^Understatement of the century...
He said something like he had a company, I wonder if he will produce some of those parts to sell or make complete electric 1/5 platforms? |
.dk |
Yo, that is some sick machining skills he has got... or shall I say, CAD skills.
That thing is more of a work of hard than anything else... can anyone say HEAVY. :surprised: :intello: |
he burned up that HUGE schulze. anyone wanna place bets schulze says the wires were too long?
Judging by the last pictures posted he might simply have connected the 2 6s batteries in series (and not in parallel as he posted). Leading to a motor RPM of around 44000rpm and to a top speed of 148km/h (92mph). Could have been too much while starting up the motor for the mighty 300A Schulze.
He was told by Schulze to use 4 instead of 2 6s lipos. Maybe voltage drop was to high for the ESC (His batteries should be able to supply up to 250A when connected in series and up to 500A when paralleled). If he really connected those batteries in series with this kind of gearing he sort of was asking for troubles. If he did run this setup with paraleled 6s batteries i wouldn't have expected the ESC to burn as gearing would have led to a top speed of only 75km/h (46mph). A speed level of 148km/h (92mph) for sure is doable with his choice of motor and ESC but amp draw would be huge with only 6s. As rhylsadar suggested in the above mentioned rcuniverse thread - wiring the motor in star config would be a solution. This would drop motor KV by a factor of 1.73 -> 578kv. Enabling him to use his batteries in series, lowering amp draw and resulting in a more appropriate top speed of 85km/h (53mph) to start this setup with. I really was sorry when i red his ESC burned. |
Very nice, gotta be heavy but still a nice ride. Thanks for sharing it.
He's not the Stig, but he is Monster Mike's French cousin... (insane quality, shame about the esc going pop).
That thing is AMAZING! I wish I had access to a CNC and CAD like that. Id be in my cave making crap 24/7:na: |
| All times are GMT -4. The time now is 10:18 AM. |
