FLM half case and G1 single speed.
for thouse of you who have this does using only 4 screws hold the trans in good? Did you only use 4 screws to hold down the chassis braces?
Do you need to put any grease in the trans? |
i think a little grease wont hurt. as for sturdiness i think it should be just fine.
It should be very sturdy, 4 screws into a CNC'd aluminum case instead of a plastic case. The aluminum wont give or strip out like the plastic might.
just remember to use thread locker.
Do you need to put any grease in the trans? If so what kind that i can get from a auto store.
no grease. i would just put a very little on the gears if you run a steel idler. you wont need much at all. i just use associated black grease.
I use dry lube in the transmission.. grease won't stay put.. at 7000 rpm, it wil fly off..
| All times are GMT -4. The time now is 03:00 PM. |
