-   -   Can i make a e-revo transmission fit on a nitro revo chassis? (https://www.rc-monster.com/forum/showthread.php?t=22430)
Hockeyplaya20 07.22.2009 02:06 PM
Yes, i know that the holes are off, because they are 2 different transmissions. So i figured, ill cut a big piece of metal and screw it on. Then i would measure how much i would need to cut. And cut a big square in the middle of the transmission. Then drill new holes. If this did work, would anything else be a problem fitting?
brushlessboy16 07.22.2009 02:10 PM
you might want to reword what your saying... cuz i have no idea what your talking about
Hockeyplaya20 07.22.2009 02:11 PM
ok, fixed the title :)
Hockeyplaya20 07.22.2009 05:44 PM
wow, im dumb... i figured ill go and try to make this mount in 1 shot deal. i cut the alum and everything. To find out it doesn't fit. i just realized i should have used some clear plastic as a template... :lol:
magman 07.22.2009 05:47 PM
I did it to my 3.3 Revo and put the 3905 trans. in...simple to do....and yes a template is a must!:yes:
Hockeyplaya20 07.22.2009 06:03 PM
thanks, trying to figure out where to put stuff now, esc where old engine mount was, battery on side (make a holder), and rx in the middle (im mounting the motor in the front making a gap in the middle.)
Would you happen to have any pics?
Hockeyplaya20 07.22.2009 09:31 PM
After making a template :yes: i finally got a outline!! :)
The holes match up perfect!!!!
So next step, cut along inside line to make hole for tranny to get in
side 1
http://i232.photobucket.com/albums/e...0722092124.jpg
side 2
http://i232.photobucket.com/albums/e...0722092125.jpg
