Mamba Monster 2200kv Combo
I was thinking ahead about my motor and maintaining it. What are the bearing sizes for the 2200kv? Whats a recommend bearing type? I was thinking ceramic ABEC 7. Thoughts?
yes i was wondering the same thing...also...is it possible to buy the end-bell/ mounting plate for the 2200 motor?
guess who didnt use long enough screws and did a big jump hehe i turned the end bell around and put the motor back in with the new threads. |
how often do you guys disasemble these guys for maintance?from the noob:mdr:
Monster anatomy
-Kevlar wrapped magnets Not carbon inside as the "real" Neu
-5x16x5mm Bearings Japan (Koyo or NMB - CNC grade, 100K RPM rated) -Laminations M19 non-oriented magnetic steel Japan -Magnets Same as Neu – China N38UH magnet -Shaft material Stainless - USA -Case T6061 – China -US source 10 gauge silicone insulated wire |
Abec 3 or better bearings should be fine, all you really need to do/ can do to maintain the MMM motors is just clean the bearings with a drop of 3in1 oil or wd40 to flush out dirt every now and then. Basically just keep it lubed- if you notice the bearings are rough, then you might want to concider changing them, otherwise, its pretty much maintainance free...
Stock bearings are 5mmx16mmx5mm ABEC 5
Some motor manufacturers say no lube the motor bearings, what do you say Patrick?
KYjelly or vaseline... :wink:
| All times are GMT -4. The time now is 06:03 AM. |
