fs LST2 parts lot
LST2 parts. Everything is in good used shape. I tried to clean everything up with degreaser and a toothbrush. Prices quoted via PM are shipped in the USA. Shipping outside the USA will be more
http://mysite.verizon.net/tbtjsnyder/tranny.jpg Complete LST2 transmission forward only conversion with gear swap. Includes an extra spur 66T or 63T ( I can’t remember which it is…which ever isn’t stock), NIP 2 speed shoes, slipper pads, 18T pinion, threaded clutch bell, 22T and 25T pinions, and some used brake & slipper parts. http://mysite.verizon.net/tbtjsnyder/hex.jpg (6) 20mm hexes with nuts and pins. 1 pin is a little short but works. http://mysite.verizon.net/tbtjsnyder/diffs.jpg (3) differentials with NIP bevel gears. http://mysite.verizon.net/tbtjsnyder/plates.jpg Hard anodized chassis plates: bottom front, bottom center, bottom rear and a top. The center plate has the part to protect the pipe cut off. http://mysite.verizon.net/tbtjsnyder/arms.jpg (6) pairs of arms. 1 or 2 of them might be a little bent. http://mysite.verizon.net/tbtjsnyder/tini.jpg Titanium Nitride gear set. I know there is some discoloration (I don’t know why) but it is only cosmetic. http://mysite.verizon.net/tbtjsnyder/mulchers.jpg 40 series Pro-Line Mulchers on Losi 420 rims Lots of tread left http://mysite.verizon.net/tbtjsnyder/shock1.jpg Shocks with yellow springs. There is some paint chipping on the yellow springs. Also includes silver springs and blue shock bodies. http://mysite.verizon.net/tbtjsnyder/shock2.jpg Shocks with yellow springs. There is some paint chipping on the yellow springs. Also includes silver springs and blue shock bodies. http://mysite.verizon.net/tbtjsnyder/steering.jpg Steering assembly including BAC link and stock servos. |
http://mysite.verizon.net/tbtjsnyder/body.jpg
Body for LST2, a 70s Chevrolet truck. There is a couple small tears. http://mysite.verizon.net/tbtjsnyder/shocktower.jpg Shock towers with extra body mounts http://mysite.verizon.net/tbtjsnyder/singlespeed.jpg The Dude Racing single speed hub http://mysite.verizon.net/tbtjsnyder/cvds.jpg (7) CVDs http://mysite.verizon.net/tbtjsnyder/knuckles.jpg Front and rear hub carriers / knuckles. Includes 6 sets of used bearings and some NIP bearings http://mysite.verizon.net/tbtjsnyder/wheeliebar.jpg MDF wheelie bar. You can adjust the angle. |
| All times are GMT -4. The time now is 01:50 PM. |
