new maxx spur
does anyone know if the new, bigger, tmaxx uses the same size and pitch of spur gear as the previous 3.3 model. the bigger tires must demand a lower ratio. can anyone confirm?
Its the same pitch but its not the same size. more teeth=bigger spur gear.
is that compatible with rrp bell? how many teeth? i recently put summit tires on my truck and it seems to be lacking in the torque dept.
it will work with your clutch bell.
| All times are GMT -4. The time now is 12:51 PM. |
