mmm wont work with castle link???
Well i finally got a MMM for my losi eight-e but it doesnt want to link to my castle link. I got it to work one time but it was after closing and opening the castle link several times. I havent been able to make it work since any ideas on what it might be???
Sometime I have to unplug mine and plug it back up a few times before it recognizes it. Not sure why but everything else is good.
are the wires backwards on the rx plug?
I have run into this one before using vista....call castle and they will walk you through a simple step of renaming a file. It worked for me the first 2 times and then the castle link stopped working. After I called, prob. solved
Do you have a different CastleLink device to try? And maybe a different USB cable? These intermittent things usually points to something mechanical (broken wire, loose solder joint, etc).
One time my MMM didn't work with castle link, but when I switched the on/off switch to on, it worked.
The wires are plugged in the right way. The esc light up yellow when I plug it in but the castle link doesn't read my esc
| All times are GMT -4. The time now is 01:56 AM. |
