2 questions about hexes
A few days ago I started a topic because I stripped my LST hexes and wanted to know how to fix it, but it went wrong :lol: Anyway, does somebody have good experience with LST1 hexes? Or should I upgrade my LST1 with a LST2 performance kit with aluminium hexes? (That would suck because I've still got 3 good tyres + rims)
And question number 2; how should I measure hexes? Losi says that the LST1 got 17mm hexes, but how the f*ck do they measure that? I measured this: http://img7.imageshack.us/img7/812/hexes.png None of them is 17mm, so how do they measure 17mm? Or am I just stupid??? |
LST1 uses 14mm hexes :)
LST2 uses 20mm if I remmember correctly |
But it's still strange, if you scroll to the bottom it says the LST1 uses 17mm, but that's wrong probably... http://www.losi.com/Articles/Article...ArticleID=1577 |
Old losi had maxx style axles and used to have 14mm.
Newer losi use standard 1/8 scale axles wow just found even 14mm hexes for new style axles. they look funny. http://www.amainhobbies.com/product_...Set-4-LST2-AFT |
Is that a nut? If so, then you aren't taking into account the thread in the nut, which will be 17mm when factored in. :smile:
EDIT: Okay, I have a bit of a hang over, and I realized what I said made no sense... disregard. :oops: |
| All times are GMT -4. The time now is 07:00 AM. |
