Can a "Stampede Super Chassis" conversion be used to convert a Rustler
Just wondering if anyone has used the Stampede Super Chassis Conversion Kit to "hop up" their Rustler. I already ordered it so I hope it works out. They REALLY NEED to make a COMPLETE RUSTLER CONVERSION KIT .... not just a Stampede version. The price difference is why I'm pressing my luck with the "wrong" conversion kit. OH, this is an electric Rustler. NOT A NITRO. Thanks for your input.
rusty's and pedes share a lot of the same parts but i dont know how it will work out but im pretty sure you can make it work.
You turn the Rustler into a 'Pede by adding the 'Pede chassis, since the servo mounting changes, and chassis braces are needed.
Is the Chassis Brace kit an absolute necessity ? or just for show ?
The chassis braces do just what they are called - they give (necessary) support to the chassis.
I would say they are necessary (whether you go with stock plastic braces or the FLM braces). Without them you only have two screws on each end holding things together.
I guess I planned on getting them anyway, as well as the tranny case and diff assembly.
I just received my diff and tranny case today...very nice parts.
I'm just hoping I don't get stuck with a modification problem due to the servo mounting position changing. Guess I will find out soon enough. We have one local hobby shop here and it sucks. It's all model trains and rockets and the such. Might have to go to Home Depot for "mod" parts, ahaha. sad.
The servo shouldnt be a problem. I had a Hitec 645 in my Pede that I took out to put in my Rusty. |
Yeah, I got the arms. I bought the whole conversion kit. -Super Stampede Chassis.
-Your Choice of Arms. You can stick with the stock arms or go with the wider arms for a wider stance to improve handling. -Adjustable Front Bulkhead -Rear Shock Tower -Front Shock Tower -Bulk Brace -Battery Straps -Turnbuckles -All Mounting Hardware Included .... and I ordered the Chassis Brace Kit ... I chose the regular length arms instead of the extended ones. |
I sure hope the kit comes with the turnbuckles or else that'd be false advertising.
| All times are GMT -4. The time now is 08:41 PM. |
