-   -   Extending switch leads on MMM? (https://www.rc-monster.com/forum/showthread.php?t=22934)
brushlessboy16 08.12.2009 05:45 PM
As the title states, will anything bad come out of this?
Foxracin 08.12.2009 05:49 PM
You can cut solder extend cut or anything you want to them as long as you dont solder directly to the circuit bored and it will not void the warranty. I have extended mine and put on a different switch and its working great.
BL_RV0 08.12.2009 06:12 PM
It's fine to extend them
brushlessboy16 08.12.2009 06:17 PM
I know that, but i thought i saw a post about the resistance of the circuit (with longer wires) messing with the esc?
just making sure.
suicideneil 08.12.2009 07:20 PM
I believe that was an issue with the older V2 escs, as per the info Patrick posted in the refurbished MMM thread (after I asked about adding a switch).
brushlessboy16 08.12.2009 07:35 PM
going to check that now..
