-   -   ESavage Question - Medusa 036-50-3300kV 5mm v2 - Gearing? (https://www.rc-monster.com/forum/showthread.php?t=23015)
rawfuls 08.17.2009 01:06 AM
eSavage Haters, go away! :intello:
If you'd like, you can help :]
Stock spur (I think 66T, definitely 32P), quite heavy truck, just ordered this:
http://cgi.ebay.com/NEW-TRAXXAS-E-RE...torefreshZtrue
It's a 18T, pretty cheap, what do you guys think? I'll get some nice pics for you guys when it's done.
brushlessboy16 08.17.2009 01:19 AM
you need more motor then a 36-50 for an esavage...
expect temps to be high
eovnu87435ds 08.17.2009 01:20 AM
with one of BrianG's most recent updates, the list of top speeds with all the pinions will show you the gear needed for the 1:1 rollout, which is a nice starting point. Also, BrianG if you see this, thank you so much for the import/export values functions! I end up using your calculator like 3+ times a day. you rock!
rawfuls 08.17.2009 01:24 AM
Not according to some of the people over at the e-savage forums...
Hmm....
suicideneil 08.17.2009 08:30 AM
How much does your esavage weight rtr? That will answer the question of vehicle vs motor required...
Wild YFZ 450 08.17.2009 10:56 AM
I had my medusa 36-50-3300kv in my E-savage and my temps never got above 140 on the ESC or motor, I was also running 21/66. That motor has no problem pushing an E-savage, The E-savage is smaller than an E-maxx
rawfuls 08.17.2009 11:10 AM
Definitely smaller than the EMaxx, I'd probably say around 10lbs, MAX.
Since I have tons of shenanigans hooked up, stock, is probably 6-7 lbs at most.
brushlessboy16 08.17.2009 12:18 PM
7lbs is hard to say- thats what a light weight 8th scale buggy weighs...
8 or 9 is probably more realistic. and a 50mm motor even on something as small as a crt.5 (5-6lbs) is pushing past 130 degrees on 3s.
Seems like your going to need more motor.
Wild YFZ 450 08.18.2009 12:16 PM
There has been a huge amount of people running that motor on E-savage forum also including me that had no problem with the motor and the temps..
