-   -   front tire ballooning (https://www.rc-monster.com/forum/showthread.php?t=23034)
Urgeoner 08.17.2009 09:48 PM
how many here with the stock e revo transmission experience front tire ballooning at WOT and how bad is it?
Kevlar 08.17.2009 10:06 PM
I had that problem, but have taped all my new tires and now it isn't an issue:
http://i417.photobucket.com/albums/p...icky/033-1.jpg
Urgeoner 08.17.2009 10:08 PM
ok...because I have packed my center diff with 500K oil and the front still balloons like crazy, so I wanted to see whet the stock transmission was like in regards to the issue.
Kevlar 08.17.2009 10:12 PM
Thats what I have too, so if you use gorrila tape on your tires, you won't be able to see the balloning, or at least it will be considerably less.
Urgeoner 08.17.2009 11:46 PM
thank kev!
wallot 08.18.2009 03:00 AM
glue holes in rims and make holes in tires.
simplechamp 08.18.2009 04:04 PM
From what I've read the E-revo center diff only has 2 spider gears so you need SUPER thick diff lock grease or else the power will unload to the front too much. Belting the tires with tape will cut down on the ballooning, but it will only mask the problem of excess power unloading to the front.
I still use the stock center locked spool. I don't see the point of buying the center diff, then doing everything possible to lock it back up again. Maybe someone will start making those 1/8th hybrid center diffs again, but until then the locked spool is your best bet for consistent power transmission
Urgeoner 08.18.2009 10:41 PM
I have a home made center diff, it's a 1/8th scale diff thats made of thunder tiger and traxxas parts. It still unloads but I can pop wheelies and ride them out now.
What's_nitro? 08.18.2009 10:45 PM
Any binding around the rear diff? I'd think with taped fronts and 500K fluid there would be no more problem...
Urgeoner 08.20.2009 08:06 AM
no binding. it's just that all my wheels/tires come assembled, and I'd hate to take them apart to tape them because I hate gluing tires.
lincpimp 08.20.2009 11:20 AM
If you have any center diff you will experience some unloading to the front wheels during hard acceleration, and during speed runs. The power will always go to the path of least resistance, which is the front wheels, due to weight transfer and aerodynamic lift to the front end at speed.
If you want to wring out the most speed possible, swap the solid tranny output shaft back in.
Urgeoner 08.20.2009 10:02 PM
ya but I kinda like the speed where it is now but thanks linc.
lincpimp 08.20.2009 11:10 PM
No prob, just trying to let you know the center diff is still unloading... Try mixing 1000k with the 500k... Or make sure that you have the diff completely full, you may have some air in there and that will make it act like it has lighter weight fluid.
shaunjohnson 08.21.2009 04:14 AM
they make 1000k diff oil?
where?
kalbien 08.21.2009 04:36 AM
where?
Linc is joking as he likes to - it's called "sand"
