-   -   Lower EPA can lower motor temperature? (https://www.rc-monster.com/forum/showthread.php?t=23044)
superek4 08.18.2009 09:13 AM
Hi, I m running a 1600kv medusa on 6s consuming about 200mah per min. Tempature about 60degrees
I have a spare 2000kv medusa if I use it on my 6s( I only have 6s)
can I lower my throttle EPA to slow it down & lower the motor temperature as well? Thx
brushlessboy16 08.18.2009 09:24 AM
no.
the only thing that will happen is that your ESC will get even hotter.
All esc's are most efficient(least heat) at full throttle- limiting them will make them heat up more.
The only thing lowering the EPA will do is make your truck slower.
simplechamp 08.18.2009 10:33 AM
Why not lower the gearing? Are you already geared down as low as you can and it's still too fast?
superek4 08.18.2009 10:48 AM
My gearing is 50/13 on my 1600kv my spare 2000kv will run 50/11 but still too hot about 80degrees within 11mins.
I was thinking how to use it if my 1600 breaks down during a race.
The other way is to use 4s.
suicideneil 08.18.2009 01:56 PM
What length are your Medusas?
superek4 08.18.2009 08:52 PM
70mm
big greg 08.19.2009 12:00 AM
it acually will make your motor run cooler because the rpms wont be out of control, about the esc getting hotter, i think thats bull, your not on full throttle very long anyway, i always lower my epa running 5s keeping the same gearing as when i run 4s and the speedo runs the same temp
aqwut 08.19.2009 12:23 PM
Changing the gearing, would be your best bet.... I lower my EPA all the time.. it does make it warmer if your gearing is the same, and with a higher kv motor...
