Bullet connector arrangement ?
How do you install your bullet connectors? Female on both battery wires?
battery :
male - female + however dont like bullets. ec5 for bigger cars, ec3 for smaller |
Where do you get these EC5 connectors? Amp rating ?
amainhobbies have them
hobbyking has a nice cheap copy that works as well it's 5mm bullet type so between what 4mm and 6mm bullets are rated :) |
I hear the TRX connectors are good too. The EC5s are around $7, which is a lot for a single connector. I'd like to see what the max amps are for both. A complete side by side comparison on many levels would be even better.
| All times are GMT -4. The time now is 08:29 AM. |
