Help brushless problems
hi guy's i am in need of your help i have finally got round to running my emaxx then i noticed a problem it only goes backwards i tried aii i can think off i was wondering if you guy's have any idea's thanks here is more info it is running a mtroniks genisis truck speed controller with a 3000kv motor of the same make thanks
we need more info.
what setup are you running, esc, motor. etc |
more info added thanks
flip any 2 motor wires.
That will solve the motor spinning backwards. if it's a drivetrain problem then try flipping the diffs upside down if you have done anything to them recently.
thank's for all the help
If it only goes forwards after you make the changes, then check the programming isnt set for forwards only too.
| All times are GMT -4. The time now is 10:37 PM. |
