-   -   Smoked 9920 (https://www.rc-monster.com/forum/showthread.php?t=2314)
Nabors 02.11.2006 10:16 PM
Smoked 9920
2 Attachment(s)
I finally got my gmaxx running this week and got somewhere around 10 runs on it. The 8xl+9920 was doing great nothing was getting over 130* good power on anything from 12-16 cells. Until today. I was playing around in the street with it normally the road rages spin bad on my street but for some reason they hooked one time and it flipped over backwards pretty hard and tons of pink smoke started poring out. When I got to it one of the batteries had been thrown out and broken a solder joint on a battery bar. The cells are glued together so it was still making contact. Any ideals on why it died? Every joint was shrink wrapped with nothing exposed to short the esc was zip tied on a 1/2" piece of foam to protect the bottom.
coolhandcountry 02.11.2006 10:21 PM
Did your batteries short out to the chassis or something?
Nabors 02.11.2006 10:37 PM
I guess it’s possible they did while coming loose but when I got to the truck it was on its roof and the pack that was loose was sitting in the roof not shorting on anything. The other pack hadn’t moved. There are no burn marks on the chassis to indicate that they did tho.
mmdooley 02.11.2006 11:39 PM
Where did the smoke come from? I dont understand why pink smoke would come from the battery or esc???
BrianG 02.11.2006 11:58 PM
Yeah, smoke from burnt components is usually a normal grayish color. Pink smoke sounds like there's some other chemical was present. Are you sure it was pink and not some trick of sunlight or something?
Nabors 02.12.2006 12:21 AM
Did you look at my pics? The esc is what was smoking only the esc is damaged. The color of the smoke doesn’t matter I just mentioned it because it was kinda cool to see pink smoke poring from my emaxx.
mmdooley 02.12.2006 12:41 AM
If nothing shorted out and esc burned out by it self it may be covered by warranty?? I would tell BK about the pink smoke.
Scott711 02.12.2006 02:38 AM
How old is your 9920? On the one I have all the wires and capacitors terminate on the same end and in your pictures I can't see any capacitors or your negative lead. On that topic how do your capacitor look? Are they bulging out the ends at all?
BrianG 02.12.2006 02:59 AM
Yeah, I saw the pics and it's obvious the ESC burnt. The color thing was weird that's all. I hate the unexplained. :)
E-maxx-kid 02.12.2006 04:18 AM
Exact thing happend to my 9920, cost 80 euros/90$? to get fixed (was still under warrenty).
maxxdude1234 02.12.2006 06:32 AM
I blew up a tekin 420g2 once, lots of green smoke came out. I guess its just something in the controller that burns a funny colour (maybe the heatshrink?)
Nick 02.12.2006 06:33 AM
Isn't it strange that all the 9920s that have smoked recently all have 2 caps...
Serum 02.12.2006 07:49 AM
This one has got no caps.. What happened to them?
that is not warranty, for that money they can have a new one made. did you payed already?
coolhandcountry 02.12.2006 09:10 AM
I thought something looked funny. Where is the capacitor?
nbcaznmaster 02.12.2006 09:14 AM
lol, u guys just noticed that? I assumed he removed them so u can see the burnt spot easier
