For you mbx-5T owners....what diff fluid are you using
I am targeting the Mugen owners specifically as I recently bought a Mugen truggy.
I am thinking of: 7F 15-30C 5R I did do a truggy diff search and came up w/ alot of different set ups....so, this is why I am targeting Mugen owners Good bad? |
20-20-5
slipperential in center for very aggressive driving style used to run 7-17-3 - not bad either |
I am only basing w/no sliperential...so your second set up would be good?
for bashing go with thicker diffs so 20-20-5 will work well
just dont forget that oil won't last forever so you need to check it/replace it every few hours of runtime :)
I'm gonna run 5K in the center for racing. Not sure on the front and rear yet.
5 in the center seems a tad light to me even for racing, but, seeing as I an new to truggies, I could be wrong
I saw another guy running 5K in the center. I thought the same thing...but I guess I won't know til I try :mdr:
I might go 10K just because I don't have a clutch and it's direct drive. Hmmm... |
Then I'm slapping in 10K for now. I think that's the highest I got at the moment. Need to stock up on MOAR.
what are the pros and cons of
a-heavier oil in the center b-lighter oil in the rear c-heavier oil in the front? i am ballooning my front tires pretty badly and find my 5t doesnt turn in very well. |
DIFF OIL
THICKNESS CHARACTERISTICS Front Thinner Increases steering into corners (off-power) If oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners Thicker Increases stability into corners during braking Increases steering on-power at corner exit Center Thinner Front wheels unload more during acceleration Decreases on-power steering (reduces oversteer) Easier to drive on rough tracks If a high-power engine is used you could waste too much power and sometime cook the oil in the center differential because it overloads More off-power steering Thicker More all-wheel drive effect Better acceleration Increases on-power steering (reduces understeer) Better suited on high-bite, smooth tracks Car can be more nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle Rear Thinner Increases cornering traction Increases steering into corner Thicker Decreases rear traction while cornering Reduces wheelspin |
That is a great explination and should be posted as a sticky somewhere!
| All times are GMT -4. The time now is 02:59 PM. |
