RC8e diff fluid
I have looked on the AE forums and only found setups for the nitro version so I decided this was the best place to get opinions for electric RC8 setup. I have been running 5/7/3 (F/C/R) I used to run 5/5/3 when it was nitro but after the conversion I went with 7k in the center to get less unloading to the front... I think it works good for me but I wanted to go up in the rear to 5k so I can maybe get a little bit more steering (loosing traction on the rear to slide it around easier). You guys with RC8e's please post your preferred differential fluid weight. :smile:
Thanks -Frank |
I would like to know the same thing. Iam building an rc8b and converting it to electric. I cant find and rc8e setups anywhere
| All times are GMT -4. The time now is 07:49 AM. |
