Technical data redline motor
TT2320 4038 2250kv
Max RPM = ? Resistance = Ohm ? Volt max = ? KT = ? Amp continuos = ? Amp Peak = ? Temperature Max for no damage rotor (magnet) = ? |
That motor is actually remarkably similar to the Neu-Castle 2200 or the Neu 1515 1Y so the specs shoud be pretty close to these:
Max Rpm = 60,000 Resistance = .006 ohms Max Volts = 60,000/2250 = 26ish KT = 1352/kv Max cont. current = 120 amps Max tempurature = 200F (really 180 just to be safe) |
| All times are GMT -4. The time now is 06:44 AM. |
