-   -   RTR 1/8th brushless buggy now available from MRC (https://www.rc-monster.com/forum/showthread.php?t=23359)
simplechamp 09.04.2009 05:51 PM
http://www.modelrectifier.com/search...w.asp?ID=10155
Model rectifier has had this on their site for awhile as "Coming Soon" and now they are available.
Seems like probably has an EZ-run system or clone. Comes with a pair of 4000mah 2s lipos, no word on the C rating. Variable damping big bore shocks. The center diff is actually contained in a diff case, not sure how that will work out.
Definitely won't be a racer, but for a casual driver might turn out to be a decent vehicle. Truggy should be soon to follow, still says "Coming Soon".
jayjay283 09.04.2009 05:56 PM
I scoffed at it as I usually do, but rtr. lipos, radio and all, nice xmas gift. just need a charger. I think you may have found my xmas gifts
simplechamp 09.04.2009 06:01 PM
I just looked at the exploded diagram and the center diff case actually has others gears in it for further reduction. Not sure about that one, seems like it would just be more gears to wear out. Unless there is some advantage I'm not seeing? More gearing options maybe?
Wonder how the lipos are?
Parts support will be another issue. I have a Team Academy buggy and it's hard to find parts at online shops, and impossible at LHS. MRC carries all the parts but they aren't cheap usually.
nitrostarter 09.04.2009 08:53 PM
Yeah, definitely has a transmission.... Not sure thats good. Probably need it for that 2700kv motor.
Arct1k 09.04.2009 08:54 PM
3 Attachment(s)
It was reviewed by myself in last months RCDriver... Actually ran 50+ right from the box
magman 09.04.2009 09:20 PM
So Chris...your impressions. I did not read the article...hence why I am asking
gixxer 09.04.2009 09:26 PM
Not for me, but I like that more electric 8th scales are coming out.
magman 09.04.2009 09:30 PM
Not for me as well...quite content w/my 2 Mugens and my crt.5:yes:
I agree w/the fact that it is nice to see more BL buggies/truggies are coming out.
anthony213 09.04.2009 10:08 PM
gear ?
im not seeing a spur gear ! any1 else see that ?:neutral:
Arct1k 09.04.2009 11:23 PM
I didn't get to use the car on the track - Track commentary was done by Greg V...
It looked like an OK entry basher... It did what it said it would do - Plug in and hit 50mph which isn't terrible...
simplechamp 09.05.2009 01:41 AM
What do you think about it having the enclosed case for the center diff and including an actual transmission?
starscream 09.05.2009 04:45 AM
From the pictures and exploded view, the center transmission box seems fully enclosed. So, how does the BL motor power the center transmission if there are no external gears?
_paralyzed_ 09.05.2009 12:52 PM
well, it's not fully enclosed. There is an opening where the pinion hits the primary...........
starscream 09.05.2009 03:33 PM
I still don't see the opening in the pictures or the exploded view: http://www.modelrectifier.com/resour..._Breakdown.pdf
But I'll take your word for it cuz you can't hit 50 mph free wheeling :whistle:
_paralyzed_ 09.05.2009 04:32 PM
I don't care for the design. No spur adjustability?
jayjay- I'll take mine in blue
