-   -   Mamba Max and Velineon (https://www.rc-monster.com/forum/showthread.php?t=23360)
jacobsjo87 09.04.2009 08:17 PM
I just got a velineon and I want to hook it to a mamba max. The mamba has 4mm bullets and the velineon has 3.5mm plugs. So my question is which plugs should I change. Im assuming I should swap the 3.5mm to 4mm. Is it ok to shorten the wires on the velineon motor?
e-rev project 09.04.2009 08:28 PM
you are correct on both, the shorter the wires the better
Arct1k 09.04.2009 08:30 PM
It will make no odds but no need to shorten wires - Just unsolder and re-solder new connections...
jacobsjo87 09.04.2009 09:26 PM
Ok thanks for your help.
e-rev project 09.04.2009 10:22 PM
it was my understanding that: the shorter the wire = less resistance which is good
