What's the most powerfull setup d8t ?
Hi !
I'm thinking of building an insane hb d8t truggy :intello: So i'd like to know how powerfull bl-motors the driveline can handle ? Would it handle an neu 1521 or even 1527motor on 6s lipo ? |
power
probably would for 3 or 4 packs. Then you would have to rebuild your transmission. Be sure to check for enough clearance on motor and to buy lipos that can handle these motors, otherwise you would be wasting your money.
maybe an 1521 would be better ?
hm what about if i would go for a nice comp setup instead ? Wht motors would be best ? on 6s lipo because i quess that i'll have to run 6s in an truggy ?
1515 2.5d or 1515 3d
You don't have to run a truggy on 6s. They can be run on 4s with good batteries. I have been extremely happy with a 1515 2.5D on 5s and many others here run that same setup.
id run a castle combo 2200kv in the truggy great on 5s and to much to handle on 6s
the 2200 combo will have u blowing the tires of with even low gearing in a truggy on 6s. i would go 4s if your just starting out or 5s if u want some real power without hurting the drive train. it should hold up on 6s as well but use caution
| All times are GMT -4. The time now is 07:16 PM. |
