-   -   IS THERE ANY HOPE----READ!!!!!!!!plz (https://www.rc-monster.com/forum/showthread.php?t=2352)
Mike.L 02.16.2006 08:23 PM
:026: :026: :026: i have by accidently took off my engin head and there was a goey seal of some kind..i did not take it offf...now i think theres no compression? is there a problem is my engin done...i didn't screw in the screws to my head because 2 are striped so if i screwed the back in would it work...people in rc-monster fourms help me out!!!:026: :035: so if i screwed my 2 screws back in tight would there be compression? is my engine done? i hope its good still and theres still hope:032: :026:
Mike.L 02.16.2006 08:27 PM
if any one! any one can help me and tell me what to do and how to fix it plz
pl when you reply that you stay on topic plz i need to find out!
HELP!:'(
Mike.L 02.16.2006 09:06 PM
noe one can help me?
come onn
coolhandcountry 02.16.2006 09:53 PM
A stripped screw for a head don't sound good. I don't know if you can fix it. You would need to get all the screws to hold the head down for it to work properly.
HotnCold 02.16.2006 09:57 PM
yep - and if you get all the screws tight - and you can spin the flywheel easily by hand - then the compression is not good - also - it will loose all low end grunt - if its got no compression - you either need a new piston and sleeve - or a new motor - sorry to be the bearer of bad news..
coolhandcountry 02.16.2006 10:24 PM
That is a problem hotncold. I don't think he can tighten all the screws up. He has some stripped. I don't know what you do to that. You may get a heli put in it. Get the stripped threads fixed.
HotnCold 02.16.2006 10:29 PM
Thats a tough one - if possible - retap and resize screws - thats about the only thing i can think of - is the motor very $$$$ - if not - it may not be worth it - also - if 2 of the screws are able to be tightened - then i think that if it is still easily spun ( flywheel ) then she is still shot - stripped screws or not -
Sylvester 02.16.2006 10:31 PM
No, he got out the stripped screws, he just didnt want to run with them in there..
Mike.L 02.17.2006 11:28 AM
ya if i replaced all four you it be alright?
like when you plug start it you hear a hiss like its escapeing..beacuse they are not screwed back in properly....so if i take all four screws out and replace em and screw in the good / new ones tightly it should be fine?
coolhandcountry 02.17.2006 01:18 PM
Oh! I thought you stripped the block part. I would put all four back in it and tighten down properly. Then check the compression. It is not going to seal if no tight. Have to do that and try it let us know how it goes.
Mike.L 02.17.2006 04:49 PM
yup
im just waiting in for some stainless steal srews..its coming with evry screw for my truck so once that comes in ill info all you into whats wrong...
im so glad its nothing else but the screw head.:D its nothing to do with the piston and the piston sleeve because it was running perfectly the other day so..im glad its all good now!
Mike.L 02.17.2006 05:12 PM
all i did was take off the head to take a look..i was supposed to switch heads but im just going to stick with the old square head for now i was going to get a round blue head of slvester but it had no head shim so ill just stick with what i have
Mike.L 02.17.2006 06:04 PM
heads
1 Attachment(s)
this is what i mean
I
I
I
Mike.L 02.19.2006 07:56 PM
3 Attachment(s)
its all good :D i got a new head i ither go big and new or go home!
thanks to slvester for the head!!!!:D heres some pics
a nice blue round head
SCREW SQUARE HEADS!:018:
Sylvester 02.19.2006 08:15 PM
No problem , mike! Now wheres my money? :D
