-   -   Rpm vs mph??? (https://www.rc-monster.com/forum/showthread.php?t=23554)
superek4 09.15.2009 09:34 PM
Rpm vs mph???
I hv this 2 motors n want to know what's the diff between these 2 set up?
I am using 6s lipo n on a CRT.
1.neu-1515/3d with 16/50spur speed 37mph, 30192 rpm
2.medusa 1600kv with 13/50spur speed 35.41mph, 35520 rpm
i am confused do we measure by speed or rpm? so which setup is faster? less rpm means less torque?
brushlessboy16 09.15.2009 09:42 PM
Rpm directly corrolates to speed.but these two cannot be directly compared because they use different kv motors and differenent gearings.
Torque is based on Kt or oz/in per amp of power. In most cases Kt and Kv are directly related..
*in most cases*
-A motor with a higher Kv will have a lower kt
-a motor with a lower kv will have a higher kt.
So running a lower kv motor (with a higher kt) on higher voltage results in a torqueier power system.
hope this helped
superek4 09.15.2009 10:07 PM
Hey thx now I know:)
zeropointbug 09.16.2009 01:14 AM
I wouldn't say that, a lower kv. motor will draw less current to do the same thing (torque), a higher kv. motor WILL draw more current to do the same thing as well. They will both be equally powerful and same torque levels for a given max rpm setup.(well, the higher voltage will be SLIGHTLY more powerful :smile: ) The only difference really is running temps, they will always be lower when you increase voltage and lower the kv. value.
