loaded ? tekno clutch with the rcm mount ?
newbie with a 8t 2.0 on the way
would like to run rcm mount, but also like to run clutch and mech brakes, can it be done ? i know tekno has to have the long pinion, and rcm makes the spur in tight, can the clutch be spun around backwards on the pinion ? or is the pinion not long enough anyways to use a front motor mount ? thought this would be the best place for these questions, however if it needs moved please do so :) |
delete, i think i got it all figured out, too long
| All times are GMT -4. The time now is 12:55 PM. |
