Diff leaking help
Hi, my slip diff is leaking, I change the gasket but still leaks? Pls help. Where should I check? Thx
Is it leaking from the gasket- or the output shaft seal...
Gasket
Hmm, make sure the alu cup is perfectly flat, no burrs or anything. Put some grease on the gasket before you instal it. Tighten the screws in a crosswise fashion. Then it should be tight.
Thx, I think I miss the crosswise thingy thx alot:)
| All times are GMT -4. The time now is 03:27 PM. |
