-   -   how to? (https://www.rc-monster.com/forum/showthread.php?t=236)
toby 03.03.2005 04:08 PM
how to?
hey i have a couple questions about the aluminum stuff. how do you remove tires from aluminum rims and is there a special way you are suppose to clean aluminum chasis when there is mud on them? also this may sound stupid but can you bend aluminum back after it breaks?
Sylvester 03.03.2005 04:54 PM
toby, you remove the tires from the rims just like plastic rims, just be percatuios if you dont want to scratch them, to clean the aluminum chassis you just get a partially wet cloth and cleaan it, than dry it, and you can bend it back but it will not be as sturdy as before.
toby 03.03.2005 05:02 PM
i mean if the tires are glued on
Sylvester 03.03.2005 05:26 PM
oh, than thats a different story , if they are glued than get a really thin hobby nife and cut around the glue, near the rim, you should use common sense. P.S my package is already in Canada! only in 3 days, i think my order from gorilla will arrive next week, im so exited :)~!!!!!!!!
HotnCold 03.03.2005 06:14 PM
tires -
I know that if you put plastic rims in the oven for a little while - the glue will burn off and you can peel the rubber off the rim. Here comes the disclaimer : I do not, I repeat I do not know if this will work with alluminum rims without damaging the rims - so if you wish to try this - perhaps wait until someone can confirm this method with alluminum - I would hate for you to ruin your rims this way - But it works with plastic rims and removing the rubbers....
Sylvester 03.03.2005 06:19 PM
Hotncold, i think it is an O.K idea BUT you must take alot of percaution, but with plastic, go ahead, rip those suckers off :) What aluminum rims would you reccomend? they also have to be nice.
HotnCold 03.03.2005 07:05 PM
RD Logics from mike - they look pretty sweet - I dont run aluminums - yet - if there was a way that was easy to switch tires - then i would probably get me a set...
toby 03.03.2005 07:36 PM
BEADLOCKS
RC-Monster Mike 03.03.2005 07:58 PM
Beadlocks don't require glue, so changing tires is pretty simple.
toby 03.03.2005 08:25 PM
that is the advantage the disadvantage is very HEAVY
RC-Monster Mike 03.03.2005 08:28 PM
You got it.
toby 03.03.2005 08:28 PM
are you sure on the weight of one? and do you know if RDLOGIC has anymore aluminum rims or where CANDYMAN got his?
RC-Monster Mike 03.03.2005 08:35 PM
http://www.rdlogics.com/cgi-bin/cate...?category=Rims
These are the aluminum rims currently available at RDLogics. I carry the "SY-V", but can get any of them.
toby 03.03.2005 08:47 PM
do you know who makes candymans? i think that netman has them too
RC-Monster Mike 03.03.2005 08:48 PM
Ramtech used to make them. They no longer offer these wheels.
