-   -   Need advice on which motor (https://www.rc-monster.com/forum/showthread.php?t=2369)
Steelerfan 02.18.2006 07:40 PM
I am going to order the 9920 and a motor for my e-maxx. None of the xl's seem to be in stock here. what is a good motor that will hit 40mph and still have excellent torque on 12-16 cells?
Sylvester 02.18.2006 08:03 PM
A 10L, thats what i went with , i am running 14-16 cells, a 10L will be good on 12-16 cells, a 8L is fastest on 12 cells, the 9L is fastest on 14 cells, and 10L is fastest on 16 cells. i Went with the 10L because i can run inbetween 12-16 cells.
Steelerfan 02.18.2006 08:35 PM
would the feigao 8l or 9l bee good choices. are they compatable with the 9920?
Sylvester 02.18.2006 08:54 PM
They are compatible with the 9920, How many cells ?
Steelerfan 02.18.2006 08:57 PM
12-14 cells.
Sylvester 02.18.2006 09:01 PM
Like i said, a 8L is good for 12 cells, a 9L is good for 14 cells and a 10L is good for all. Lets say you use 12 cells, you can use a 10L and get better runtimes with less "punch".
coolhandcountry 02.18.2006 09:08 PM
The 10L would have little less heat with the 12 cells to.
E-maxx-kid 02.19.2006 06:33 AM
12-14 cells, I would say 9l, unless you ever wanted to try 16.
Steelerfan 02.19.2006 07:21 PM
i got the 9l. what gear will work with the stock 66 tooth spur gear?
Sylvester 02.19.2006 08:54 PM
id try a 14 or a 15t pinion to start off with. The stock spur wont last you very long.
nbcaznmaster 02.19.2006 08:59 PM
9L is good, thats wut i got, I might sell to u if ur intersted. lol
Steelerfan 02.19.2006 09:09 PM
thanks, what kind of spur will hold up? this is an expensive hobby. my e went into the pond and fried all stock components. i have alot on order this week
