-   -   Swap Neu motor wires for silicone? (https://www.rc-monster.com/forum/showthread.php?t=23714)
kazuaki 09.25.2009 01:56 AM
Is it possible to convert a Neu with the standard stiff wires to have flexible silicone wires? Or is this asking for trouble?
phatmonk 09.25.2009 01:53 PM
I beleive the hardwires are part of the Neu motors windings and you shouldnt cut them.If that was what you had in mind.
MetalMan 09.25.2009 03:42 PM
Really Neu would have to do this for you. Each of the tiny wires have thin insulation on them that must be removed to get solder to stick to the copper. Neu does this on the last ~1/4" for you, but it might not be easy for them to do it closer to the can.
kazuaki 09.25.2009 03:45 PM
I see. I did not realize there were individual wire inside the big one. So, is it safe to bend the stock hard wiring to get it pointed the way I want? Maybe warm them with a heat gun a little first?
MetalMan 09.25.2009 03:48 PM
You can bend them, but try not to pinch them while doing so. If they are bent too much they are likely to break.
kazuaki 09.25.2009 03:51 PM
Nothing is ever easy...
PBO 09.25.2009 04:12 PM
I bent mine by hand over the shaft of a screwdriver...it gave the bend a nice radius albeit kinda permanent
kazuaki 09.25.2009 04:22 PM
Good idea. So basically like bending tubing. Thanks
