this is the right way to do the welding in the RX8!
Link to an italian forum... :neutral:
I guess you mean soldering, not welding. Right? Cheers Daf |
yes, right
I've seen people solder their RX8s that way, and you're only turning the wire 90 degrees, it should be fine.
Just heatshrink? :neutral:
Us English only speaking forum members are having some difficultys understanding the point ?
he means soldering the wires parallel and on top instead of at a 90 degree angle too the prongs.
i think i like it ! easy to cover with heat shrink that way. |
Doesnt make much of a difference.
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/5QktbPHdvQA&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5QktbPHdvQA&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Am I the only one that just sees a white square?
i dont even see a white square lol guess a pick didnt load right
My guess is that its the youtube link to tekin's "how to solder the rx8" video
I currently have my Tekin hardwired. I bought some 6.5mm bullets to add, but I'm a little confused on where to add them. I want to add the bullets in the middle of the wires, but then the three bullets will hit each other while driving. What are others doing about this? I don't think heat shrink is durable enough to survive that long.
I want to use those bullets so I can swap motors with my MMM combo in my Revo. |
sorry wrong link
| All times are GMT -4. The time now is 06:02 AM. |
