Intellect Life RX pack in Mini Slash?
Just a query, could I use this as a battery pack in a Mini Slash
http://rcmarket.com.hk/product_info....oducts_id=6537 The dimensions seem about right, better than a couple of the 1100mah 18650 cells side by side anyway, and the stock nimh is 1200mah, these should be able to deliver at least at 20/30C (as most Life can?) |
you could run those in series too!
| All times are GMT -4. The time now is 05:09 AM. |
