-   -   Trim Motor Wires on Savage Flux? (https://www.rc-monster.com/forum/showthread.php?t=23793)
fastbaja5b 09.30.2009 10:32 AM
Ok, has anyone shortened the motor wires on the Flux yet? They seem to be WAY too long given the ESC location. I know the Castle NEU motors can have their wires clipped but can the Savage Flux or is there some strange reason they are almost as long as the chassis?
MetalMan 09.30.2009 10:39 AM
Shortening those wires can only help, provided you are able to create a good solder joint between the (newly shortened) wire and 6.5mm plug :wink:
needforspeed 10.02.2009 05:38 PM
I had a pain,I had too buy a new solder gun ,30 watts did not get it.Then I drilled out the plugs too clean them, and went too far on one and made a hole through the bottom.4 hours later I was done.
Moral of the story-Buy new plugs and dont try to be cheap like me!
suicideneil 10.02.2009 07:34 PM
Drilling the plugs to clean them? If you're talking about the wire side where you solder it into, you dont need to clean it, just reheat the solder & maybe add a little more as you stick the wire back in to solder it in place; just use good quality rosin cored solder.
needforspeed 10.03.2009 08:33 AM
sounds dumb i know,But my old cheap solder iron did not melt cc's high temp solder.lol
Its not a problem any more
