-   -   mbx5t-6t compatibility? (https://www.rc-monster.com/forum/showthread.php?t=23842)
kneedeeppow 10.04.2009 03:23 AM
hey there guys
i was wondering if the mud guards (eo414b/c) from a mbx6t can be used on a mbx5t? or are the rear lower arms compatible between the two?
wallot 10.04.2009 04:08 AM
mudguards - yes, however :)
first and last hole is direct fit. you will have to redrill two midlle ones and use lock nut to secure the mud guard.
http://img.rcx.cz/nm2.jpg
i use mbx6 mud guards on my mugen as they are much taller in front
arms. they should however it I would go for complete (lower/upper arm) swap as the geometry is different.
also at least on mbx6 buggy the arm material is different from mbx5 and does break more easily.
kneedeeppow 10.14.2009 03:30 AM
are the hinge pins from a mbx6t compatible with a 5t?
