-   -   Are the ICE HV controlers coming soon? (https://www.rc-monster.com/forum/showthread.php?t=23874)
nl12 10.05.2009 06:18 PM
Are the ICE HV controlers coming soon? Like say this year? or will it likely be longer?
sikeston34m 10.06.2009 05:00 PM
I've been keeping a watchful eye out for this also.
The new ICE Controllers coupled together with the Mamba Software will be the absolute controller for me.
I asked Patrick if this is something we could expect for Christmas and he said "should be".
I'm aware that stuff happens, but I will continue to watch and wait.
It's hard to imagine a 50 volt ESC in the form of the ICE 160 that's truly capable of 160 amps and capable of 12S operation.
Finally a ESC like this!!! :yes:
BrianG 10.06.2009 05:15 PM
When they do come out, I imagine 1/5 scale builders and high speed freaks will be snapping them up! No more shoe-horning an airplane ESC into a car!
crazyjr 10.06.2009 05:19 PM
Will it be across the whole ICE line? or, will it be only the 160 model?
nitrostarter 10.06.2009 10:27 PM
I would like to see the Mamba Software available for the ICE controllers that are already out.
sikeston34m 10.06.2009 10:59 PM
Aaaah, I see what you're getting at! :yes:
The Phoenix Ice 100 can handle 100amps at 8S!
If the Programmer could come up with the Mamba Conversion to the Ice Hardware, it would be a simple matter of updating the firmware.
Download, update, Blam! 8S Controller with working reverse and Mamba Brakes!
Not only that, but let's not forget about the DATA LOGGING!
I would buy a Phoenix Ice 100 NOW IF they were firmware upgradeable.
I have everything here to do a 8S setup for my E Revo except the ESC.
Hmmm............shall we bribe them with Pizza? :whistle:
whitrzac 10.06.2009 11:14 PM
we're going to need alot of pizza...
nitrostarter 10.06.2009 11:18 PM
The ICE 100 should be well capable of handling a 1000-1500kv motor on 6-8s....
My g4 maxx would love 8s and a 1515/1.5Y...
sikeston34m 10.06.2009 11:22 PM
3.6 volt per cell average on 8S at 100amps is 2880 watts!
That's right at 4 HP!
Of course, my E Revo setup would be alot milder than that, but think about the efficiency. :yes:
nitrostarter 10.06.2009 11:26 PM
Definitely efficient! They should run extra cool!
I'm looking into some 4s packs right now to prepare for this adventure!
sikeston34m 10.06.2009 11:31 PM
I have two sets of matched 4S packs that fit the E Revo.
They are Flightpower 25C 3700mah. These are good for 92 amps continuous, 185 amp Bursts.
I could gear 14/52 with a 1500kv motor and still surpass 40mph. I'm sure the acceleration would be nutso.
Let me know what Lipo options you find out there.
lincpimp 10.06.2009 11:42 PM
Some of the lower mah 35c hyperion g3 packs would be extra nice for a hv setup.
I plan to run a 1521 2y with 10 3200 30c fp lipos and the lt10s esc. This would be in the 6x6 lst geared for 35-40mph tops. I had also thought about running the lt10s with a 1527 2y I have in a 5th scale savage project, and lutach said to give it a try and report back. That is a 100 amp esc and 100 amps at 37 volts is a decent amount of juice!
I will be interested to see what CC comes out with...
MetalMan 10.07.2009 12:35 AM
With regards to CAR software on the ICE 8s controllers: are their FETs rated at a high enough voltage to allow 8s operation while using motor brake?
BrianG 10.07.2009 12:38 AM
I'm sure it can be, provided there are enough TVS modules to handle those peaks...
crazyjr 10.07.2009 12:04 PM
The reason i asked about the whole line, I want a 6s capable esc for a mini e-revo. I also don't think i need 160 amps on any other esc, though the thought of the power is impresseve
