-   -   New firmware 3.18 for MMM (https://www.rc-monster.com/forum/showthread.php?t=23965)
mistercrash 10.11.2009 11:39 AM
http://www.castlecreations.com/downl...-download.html
Nard Cox 10.11.2009 12:01 PM
Did you already try it ?
Castle Link:
  • Bug preventing some nationalities from being able to run Castle Link correctly has been fixed
  • No longer have to 'Run as Administrator' to store your default motor-pole / gear ratio setup
Castle Link Graph Viewer:
  • Added ability to display temperature in degrees C or degrees F
  • Added ability display actual head-speed or prop-speed by entering the gear ratio
  • Removed menu items to select individual data-curves, instead simply click on the label below the graph
  • Added a 'How To' help menu option
  • No longer have to 'Run as Administrator' to change your motor-pole / gear ratio or temperature setup
Source
BL_RV0 10.11.2009 12:02 PM
Ooh cool. Going to update now.
mistercrash 10.11.2009 12:03 PM
I installed it on my computer and updated my ESC but I haven't tried it yet. I'm recharging a couple set of batteries right now.
needforspeed 10.11.2009 12:07 PM
Thanks,I got it 2 days ago.I should have posted it then. Or maybe they could send a automatic e-mail to people in there database to let us all know.But hey Im not complaining
SunnyHouTX 10.11.2009 12:36 PM
The change I like the most is that you can now program the Mamba Max via receiver cable like the Sidewinder. So now I don't have to dig my ESCs out of my drag cars every time I need to change the tune. Very convenient for me. Thanks Castle!
mistercrash 10.11.2009 03:39 PM
Here's my full review on the new software:
I tried it and it works. :lol:
Hey that's as technical as I can get with the knowledge I have.
Arct1k 10.11.2009 03:48 PM
wow..
Mamba Max:
Added ability to program Mamba Max via the receiver cable with a Castle-Link device (instead of being required to plug the unit into a USB port)
BUT IS THE DRAG BREAK FIXED?
phildogg 10.11.2009 04:04 PM
Originally Posted by Arct1k (Post 326543)
wow..
Mamba Max:
I like that!!
phil
Semi Pro 10.11.2009 04:48 PM
wow..
Mamba Max:
best update so far :yipi:
brushlessboy16 10.11.2009 04:48 PM
New software runs 4s fine :)
Freezebyte 10.11.2009 07:00 PM
Darn, no ability to change fan temp adjustment. And what and where is this temperature thing? And whats wrong with the drag brake? I've never had an issue with it :neutral:
Arct1k 10.11.2009 07:32 PM
Drag brake sucks for rock crawlers - Brushed thing...
Freezebyte 10.11.2009 10:10 PM
You can take turn it off completely
Arct1k 10.11.2009 10:26 PM
Eh don't follow - On a crawler you need and run with 100% drag break...
