WTB: Old computer motherboard
I was doing a little inventory and it seems I have enough spare PC parts to put together a PC, sans motherboard. Anyone have a mobo that supports the OOOOLLLLLD AthlonXP 2400+ CPU? Someone sent one to me a while back but many of the caps are puffed and I'm afraid would make the system unstable. Replacing them is a PITA (been there, done that). Cheap would be good. :smile:
I believe I have an Iwill XP 333-R sitting on a shelf, I will look in the morning to make sure I still have it.
is it a 478 pin?
cause i have multiple old school MB's. but not that old maby, i have an old intel and a gigabyte GA-8simlh |
AMD Socket A, whatever pin count that has (didn't want to count them :smile:)
Edit: The socket on the mobo with bad caps says "Socket 462", so 462 pins... |
Litterally just pitched one 2 weeks ago. Id would have given it to y. The hard drive crashed on the old girl and I just bought new to replace. It was just time. I had it sitting in the corner here for like 3 months and finally just yanked the hard drive and any other possibly usefull parts and pitched it. Wish i would known. I felt bad tossing it when it still worked. Just didnt have a use.
I have a bunch of old computers in my basement i'll check for you when I get home from work.
Never mind.
So, anyone have anything kicking around in their basements? If not, I may just get one of these: http://www.tigerdirect.com/applicati...805&CatId=1350
or just search eBay for something. It doesn't need to have overclocking or whatever. It's just going to be used as a development web server. Might make it dual boot so I can run IIS/ASP/SQLExpress and Apache/PHP/MySQL. |
I checked with my buddies, and all the oldies stuff have been scrapped.
Heck I still have a dual xeon workstation that I'm trying to get rid off. It's like a rock but it's considered old and scsi drives are considered stone age compared to the sas drives. |
I'll have to check but I think I had one with a AMD K6 and the other one had a Athlon processor in it. I'll check tonight.
Jeff |
Thanks guys. Not a big deal if nobody has one; I just figured it would be better to recycle something instead of buying another mobo that will also end up in a land fill someday. :smile:
Ebay has a few boards that will work, as well as TigerDirect. |
Brian I have an ECS motherboard K7VTA3 that has a 462 socket the processor that is in it says AMD Athlon, the other one is also an ESC but has the AMD K6 in a socket 7. Since I am not a computer guy (no really) I am not sure if this is what you are looking for or not. I was going to chunk them this weekend, but didn't so if they will help let me know.
Jeff |
Actually, the K7VTA3 sounds like the perfect match. PM me if you want to get rid of it and we can work out the details, payment, etc.
Thanks a bunch! BTW: Do you happen to know which rev it is? I want to download the manual and there are 7 revs. :oh: |
Says Version 8.0 on the board between 2 of the PCI slots.
| All times are GMT -4. The time now is 10:16 PM. |
