Loose front bearing slot on Neu motor
My Neu 1512/2.5D/Q had been running poorly and loudly in my RC8 for a little while. A few weeks ago, I took it out to have a look, and apparently there is a fraction of a gap between the outer edge of the front bearing and the motor can. Has anyone else experienced this happening to their Neu motor? If there's a way for me to fix it on my own, I want to know. I've become less interested in 1/8th scale lately, so I'm not entirely willing to send the motor back to Steve for some costly repairs, if they even exist.
Aluminum foil? Teflon tape? CA glue?
Yeah, I'd say just do something like line the edges with some Silicone Sealant just to prevent the bearing from banging around (which would cause more problems beside enlarging the hole).
Replace the bearing and apply threadlock when installing the new one. If the gap is larger than 0.1~0.2mm, you can eigher fill the gap with metal foil and glue, or machine the front endbell to make it suitable for a larger bearing like 5x14 or 5x16mm.
I tested the motor again without doing anything to remedy the bearing problem, and holy crap did it sound bad. Far worse than before, even! It wasn't as fast, either. It's honestly baffling to me as to what may have caused this; I never recall the motor climbing over the 160dF mark. I'd always had the front screw holes sealed with electrical tape, and I'd never opened the motor.
Since I wasn't worried about salvaging it, I decided to glue both bearings into their slots to see if that would help at all. The glued made a strong bond and eliminated the play altogether. But the motor ran no better than before. This time, I opened it up from the back and took a look inside. Nothing seemed out of the ordinary, except a couple loose metal flakes from where the screws that hold the back on had been drilled out. The glued-in bearings were both as solidly anchored as before. So I guess we can wrap this up by saying: -Sorry the motor turned out bad, otherwise you would have gotten a good deal, superek4. -Next motor I'm gunna get will be the MMM 2200. |
I had the same issue with my Neu 1515. Reason beeing a crappy motor mount. If you can push the rear of your motor somewhat to the side with your fingers while beeing mounted than chances are good that due to shocks while driving the motor shaft changes alignment to the spur and the pinion is pressed against the spur which over time results in a gap where the front bearing sits. Did you have to change the spur and/or pinion oftenly due to wear? Did your pinion often came loose? Those are signs that the motor is able to flex when mounted. A stronger motor mount remedies those issues. Maybe you are able to support the rear of your motor too. I changed the front bearing, wrapped the new one with alu foil and glued it back into the can. Doesn't sound like a new one and i can feel some slight vibrations (rotor has some scratches from dust and is not perfectly balanced any more) but it still does its job. |
Just for the record, I'd like to end this thread by saying that the motor was officially dead.
My friend took it apart and inspected the windings, and found a deep-rooted kink in a wire. He can't fix it, the motor's trash. Time for a MMM! |
| All times are GMT -4. The time now is 03:59 AM. |
