Ezrun 150A Feigao 11XL
I'm new and this is my first post here so hello!
I have a E-REVO with the following setup Ezrun 150A Feigao 11XL 6s lipo (5000mah zippy's 20c 11,1v) Wat is a good pinion/spurgear gearing? I don't wanne do speedruns i wanne race with it. Best Regards from the Netherlands:mdr: |
You made a great choice for motor on 6s, I tryed a setup using a 23 tooth pinion using BrianG's calculator
Differential Ratio: 2.8461538461538463 Transmission Ratio: 1.8333333333333333 Other Ratio: 1 Spur Tooth Count: 65 Pinion Tooth Count: 23 Total Voltage: 22.2 Motor KV: 1516 Tire Diameter (inches): 5.9 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor Coil Resistance: 0.0138 Spur/Pinion Ratio: 2.83 : 1 Total Ratio: 14.74638 : 1 Tire Circumference (inches): 18.54 inches (470.8 mm) Rollout: 1.26:1 Total Motor Speed: 33655.2 RPM Vehicle Speed: 40.06 mph (64.35 km/h) Effective KV Value: 1516 KT constant: 0.89 oz-in/A If you use a 22 pinion, you'll be around 37 and with a 24 you'll be at about 42mph, here is the link to the site if you want to try some different setups. http://www.scriptasylum.com/rc_speed/index.html BTW, Welcome to the forums |
A good starting point would be 18T to create a 1:1 rollout ratio. Speed will be around 31mph, which isn't too bad.
Thank you guys:mdr:
| All times are GMT -4. The time now is 09:47 AM. |
