-   -   supermaxx diff kits (https://www.rc-monster.com/forum/showthread.php?t=2406)
stampy 02.21.2006 09:39 PM
supermaxx diff kits
Ive got 2 questions about there 6 spyder ultra light kit. 1. Does it do the front and rear diff? 2. Is the diff case the same size and a stock diff case?
squeeforever 02.21.2006 09:57 PM
yes, its for the front AND rear and im pretty sure it will work with your truck since they fit in the stock bulks they should fit in yours.
coolhandcountry 02.21.2006 10:46 PM
it fits where the standard diffs fit. It you have something that is close to it diameter wise it may be a problem.
stampy 02.21.2006 11:12 PM
cool just the anwsers i was looking for :)
Sneeck 02.22.2006 01:55 AM
I'd suggest getting the 8 spyder's over the 6's. Alum housing mean's it won't twist, plastic housing can twist under power and thus destroying the little spider gear's inside.
stampy 02.22.2006 04:39 AM
how much does mike sell them for?
Serum 02.22.2006 12:32 PM
i guess about 70 dollars.
The 6spiders use poor molded gears inside the diff.
The reason Sneeck gave is not true, the plastic diffcups of the 6spiders are very tough. the output is also from metal.
Sneeck 02.22.2006 12:49 PM
Not true? Try telling that to some UE forum member's who did twist the 6 spyder housing. It take's some power to do, but it isn't as strong as the 8 spyder's, thus for the difference in money you'd be better off with the 8 spyder's.
I'm not lying here...
Also there are better gear's availeble for the 6 spyder's, don't know if these will fit the 8 spyder's too.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCWK1&P=7
stampy 02.22.2006 04:10 PM
ok i think the 8 spyders are the ones im going to upgrade to in the future. tnx guys
stampy 03.03.2006 04:52 AM
1 last q? guys do the 8 spyder diff kit come with the pos cast steel spyders or are they machined . if they are cast would the gears that sneeck posted work in there to say if i got 3 packs of em
Sneeck 03.03.2006 12:53 PM
Yes there casted. No I don't know if those will fit, they are for the 6 spyder diff's. I'm not sure if it will fit since the spyder size could be smaller with the 8 spyder's.
Worth a shot though.
But really, it take's some real effort to even damage those casted gear's. It's been done plenty of time's, but that doesn't mean you'll break it with a brushless set-up.
