-   -   voltage vs efficiency?? (https://www.rc-monster.com/forum/showthread.php?t=24077)
Gallagher 10.17.2009 12:56 AM
Motors with lower kv and higher voltage will have higher efficiency?
Virtually I can get efficiency near 100% if I get 100 kv and 350 volt, for instance?
In the other way, Neu 2200kv with 4s and 1500kv with 6s both have 90+% efficiency?
suicideneil 10.17.2009 06:18 AM
Efficiency isnt just reliant on high voltage and low kv, the motor, esc, and batts all play a part, as do the laws of thermodynamics... In short, you would need the most pure of pure copper wire and solder for the efficiency to climb over about 90%.
Using high voltage & low kv means you use less current to make the same amount of power as a lower voltage & higher kv setup, so that does lower the energy lost as heat, but you are still limited by the materials and contstruction methods of the components in the system.
For the typical racer or basher, a 6s lipo & ~1700kv setup is about as good as you can get; something like 12s & 800kv is better for 1/5 scale models that suck current like... yeah... :wink:
lutach 10.17.2009 11:00 AM
I'm loving my truggy's set up. I use 8S lipos (2 4S ranging from 3200-3700mAh), a Neu 1515/2Y (1100Kv) and nothing gets to 120F degrees.
bdebde 10.17.2009 02:10 PM
It is not so much efficiency numbers, it is more about current (amps). It takes a given amount of watts to move a vehicle a given speed (varies with every set up). Say it takes 1000 watts to move the car, you could use 10 volts which would draw 100 amps and things would get hot, or you could use 100 volts and only draw 10 amps and everything runs cool. More heat in the components can cause efficiency to go down as well as more power wasted to heat.
Motor efficiency doesn't change much no matter what the kv but y winds are often more efficient (lower kv than the d counterpart). My lehner 1930/8 is rated at 90% efficiency as d wind but when reconfigured to y wind it is rated at 92% for example.
stum 10.17.2009 09:20 PM
8s 3700mAH is sick huge, you race w/ a brick like that on your truggy? Even a 3200 8s is a monster pack, bigger than I want on my race trucks. What is the weight of your packs? Got some picks of this beat all put together? 800g for cheap lipo's up to about 1000g for pricey 8s setups good thing you don't need 35c lipo's at that voltage the Hyperion vx 35c's would be like 1400g
lutach 10.17.2009 09:51 PM
Not big at all, each pack weighs about 340-395G. I used 6S 5000mAh (2 3S 5000mAh packs in series and each pack weighs 395G) as well and they weigh about the same. I can use good 2200-2650mAh and still get decent run times. I did race my truggy with the RC-Monsters last year and missed it this year. My truggy is pretty light and that's why I can get away with such set up. Here are some pics: http://i260.photobucket.com/albums/i...h/DSC02000.jpg, http://i260.photobucket.com/albums/i...h/DSC02001.jpg, http://i260.photobucket.com/albums/i...h/DSC01459.jpg, http://i260.photobucket.com/albums/i...h/DSC01458.jpg, http://i260.photobucket.com/albums/i...h/DSC01457.jpg, http://i260.photobucket.com/albums/i...h/DSC01456.jpg, http://i260.photobucket.com/albums/i...h/DSC01455.jpg, http://i260.photobucket.com/albums/i...h/DSC01434.jpg, http://i260.photobucket.com/albums/i...h/DSC01433.jpg and http://i260.photobucket.com/albums/i...DSC01346-1.jpg.
stum 10.17.2009 10:51 PM
I've been running 5s 5k packs this year that weighed in at about 665 grams on my 1515 2.5d/f in my 8ight-t, but this next year I'm stepping to a 4s 6500 35c hyperion pack (685g) for most races w/ a Castle 2200. I'll use my SMC 4s pack (842grams) for those few Sunday a-mains when I need to race for 30-45min against nitro's; this will keep me at one battery swap, giving me a chance to stay near the top.
18.5*5k=92500
14.8*6.5k=96200
14.8*9k=133200
59.2v*3200=189440 (pushing 2x as much run time as my normal setup)
SpEEdyBL 10.18.2009 12:11 AM
My Tekin 1900 on 6s, for instance, runs a good 10-15 degrees cooler than my 2650 on 4s. It also seems a lot more powerful, almost like the 2650 on 5s.
Btw, for 6s i use a 35C 3300mAh Hyperion G3 pack (529g) and for 4s i use a 25C 5000 mAh Zippy pack (497g).
florianz 10.20.2009 02:04 AM
@ lutach
isn't that a chassis made by Mr. constructor??
lutach 10.20.2009 09:18 AM
Originally Posted by florianz (Post 328430)
@ lutach
Yes. I'm actually waiting to see if he'll have the V2 for the Mugens.
florianz 10.20.2009 09:51 AM
cool. I really like the lightweight-design of his chassis. he's from hamburg, too.
lutach 10.20.2009 09:56 AM
Go knock on his door and ask him when the V2 for the Mugens will be out lol.
doo540 10.20.2009 11:41 AM
hello Lutach
what esc are you using to run 8s? specs?
Please clear your inbox when you have time too.
doo540 10.20.2009 11:45 AM
what kind of truggy is lutach showing us in his pics?
any info on that setup would be great.
jzemaxx 10.20.2009 11:48 AM
Mugen MBX5T I believe
