-   -   Mugen MBX5T runtime help (https://www.rc-monster.com/forum/showthread.php?t=24104)
xsmoker 10.18.2009 08:41 PM
Ok, got my Mugen from ebay, and I really like it. Took my hobbywing 80A and 2000kV motor and dropped it right in since it came converted already. Bought a set of AKA city blocks (premounted) and hit the track. My setup is duel 7.4 lipo's 5000 at 35c. My gearing is this:
front/rear dif ratio: 4.3
transmission ratio: 1
spur gear: 46t
pinion gear: 18t
battery voltage: 14.8
motor: 2000kV
tire diameter: 5.5"
ballooning: 0.5"
This gives me the the following results:
Spur reduction ratio: 2.56:1
total reduction ratio: 10.98889:1
Tire Circumference: 20.42 inches (518.68 mm)
Rollout (?): 1.86:1
Total Motor Speed (?): 29600 RPM
Theoretical Maximum Vehicle Speed (?): 52.09 mph (83.67 km/h)
Calculated Loaded KV Value (?): 2000
Calculated KT Constant (?): 0.68 oz-in/A
My problem is I think that I'm overgeared. I was going to drop to a 15 or 16 tooth gear. I need to make 15 minute main and I only lasted 9.5 minutes!
I could run 2 4s 5000's in series to get the time but I don't want to run that much battery if I can avoid it.
What is the ideal numbers I'm trying to get with gearing? What total reduction ratio should I be trying to get, final spur reduction ratio?
Is it possible to go 15-20 on a set of good 5000 30-40c batteries running at 14.8 (7.4x2)? I want to avoid running at 5C because the 80A hobbywing is rated for 4C.
Thanks,
X
brushlessboy16 10.18.2009 09:04 PM
52mph is wayy too high. gear for just under 40.
How hot does that setup get? gotta be smokin'
xsmoker 10.18.2009 09:11 PM
Yes too hot! Although I just got my Turnigy heat sink and fan and it is almost too big but I am overgeared. I'm gearing down and going to put a hole in the front for airflow. Besides mph what should I be trying to get with the gearing numbers?
Can other people make 15-20 min mains with a 14.8 5000mah pack?
jsr 10.19.2009 02:36 AM
I think you should be able to make a 15min main with a 2000kV motor on 4s. Most people look at the top speed to set their gearing. As brushlessboy said, go for just about 40mph...that's a good general target for most tracks. If you have a huge track, you might want to gear for a bit more top speed for long straights, and vice versa for small tracks. If you gear for say 37mph, you'll probably make the main fine.
danhfvcsd 10.19.2009 06:17 PM
Here's some info that may or may not be of help to you... i think you should be able to make 15 minutes easily enough =)
Packs: 2x 2S2P 28C SMC 9000mah Lipos wired in series for 4S
Vehicle: MBX5-T (Geared 14/46 Long Shank Pinion - apparently 4.8kg RTR says my unreliable scales at home)
Electrics: MMM/Tekno Neu 1512 2.5d/f
Race/s Vehicle Run In (Runtime): 2x 6 minute qualifiers
Temps: Batts: 110f - Motor: 130f - ESC: 110f
Cell Voltages BEFORE Charge: Pack 1 - 3.72v/3.74v - Pack 2 - 3.72v/3.74v
Cell Voltages AFTER Charge: Pack 1 - 4.20v/4.20v - Pack 2 - 4.20v/4.20v
Mah Charged Into Pack: Pack 1 - 6462Mah - Pack 2 - 6572Mah
Charge Time: 111 Minutes : 53 Seconds
Peak Pack Voltage: Pack 1 - 8.422v - Pack 2 - 8.407v
Pack Resistance: Pack 1 - 3mΩ - Pack 2 - 5mΩ
xsmoker 10.19.2009 06:42 PM
Thanks guys,
I got a 15t pinion in today and went down to the track. Still has good top speed, runtime was about 18 minutes. I think 14 will give me exactly what I need. I guess I should invest in 6-8K packs to guarantee my run time.
X
BL_RV0 10.19.2009 09:40 PM
Just get multiple 5k packs and switch them out rather than 1 heavy battery.
xsmoker 10.19.2009 09:46 PM
I have multiple 5000mah packs, and I switch them out between races. Qualifiers are 5 minutes. My issue is only the main. I think I'm 1 gear away from making 15 minute run times. My local track runs nitro with electric so we have 15 min mains. After practice today, I feel better running the 15t with a pair of 2s1p 5000 7.4v packs. With a 14t I should make 15 min mains no problem. In the off season I'll get a pair of 6 or 8K packs just to be sure in case they raise the mains to 20 minutes. Nothing is worse than trying to beat nitro only to not have enough batteries.
X
