Reverse rotation
If I unplug the sensor wire on my rx8, can I reverse motor direction by switching any two wires?
no need to you can change the drive profile for reverse rotation without physically changing anything- and even retain the sensor wire.
Read through the Rx8 Manual Pit tune>>> Motor Drive type(MT)>>>set it so all LEDS are on and reboot the esc. |
sweet! that works in sensored mode right? I thought I needed the hotwire LOL
Yes it does work in sensored mode too. My RX8 was in reverse rotation when I was running my Losi motor, then when I switched back to the T8 it was still reversed - and worked. I then set it back to the correct way round (for my set-up).
| All times are GMT -4. The time now is 10:34 AM. |
