-   -   Computer Power Supply (https://www.rc-monster.com/forum/showthread.php?t=24129)
maxair45 10.19.2009 07:50 PM
Okay i got home today from work and nothing good was on so I decided to see if I could pull a few fans and a power supply from an old computer. I got a fan, magnet, and what looks to be a power supply(90% sure it is). I have a few questions on it. I have no idea what this thing can do so I was wondering if any of these numbers would tell me if this has enough power to power a duratrax ice charger. Info:
DC Voltage Max Current
+12v 4.4A
+5v 20A
-5v 0.2A
-12v 0.5A
Anyone know what this means? Also there are a BUNCH of wires comming out of the end I would plug the charger into. I have the one side where I plug it into the power strip ready for use but the other side has to have 30+ tiny wires comming out if it into a wired connector that plugs in inside of the computer. Would I need to open up the power supply itself and find the wires I need? What do I need to do? I don't NEED a pwer supply but I though it would be fun to try and get my own.
All help is greatly appreciated
Thanks
BrianG 10.19.2009 07:55 PM
You'd be using the 12v line for chargers, and that is only rated for 4.4A. Not nearly enough to charge any kind of car lipo unless you stick to a 1A charge rate or something.
I could go on to tell ya how to do the wiring, but that supply is not really needed TBH. But, if you want to take a stab at it, there is a sticky in the general electric subforum that explains how to do the conversion.
whitrzac 10.19.2009 07:56 PM
few good parts to salvage
magnets from INSIDE the hard drive
caps off of board
ferite rings off of board
your power supply is a POS though, its only a 4.4a max...
maxair45 10.19.2009 08:01 PM
Ah it was worth a try. The thing is OLD. Its should be in a museum. I see another fan a possibly a magnet inside it so i'll snatch those up. Its amazing how much dust collects inside of your computer...
